跳转到主内容
加入维修社区 - 创建账户
苹果第四代智能手表,带有可选的蜂窝网络功能,于2018年9月21日发布。
Ribbon Cable Damaged?
Dies the Ribbon Cable look damaged to you ? Because it looks a little bit bend and i want to be sure, to buy a new screen.
I also connected the broken Lcd and it showed the half of the screen. Can you help me pls ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have a similar problem but far more serious I think. My cable tore completely on one side. Before removing the damaged screen the watch displayed the “connect to charged” lightening bolt icon. After connecting The new screen I have a dead watch. No life at all. Can the cable be replaced? If so, where can I get it?
由完成的
添加一条评论
1个答案
已选择的解决方案
Well, the good news is the ripped cable is a shield to protect the signals within the other segments from distorting other signals. You will need to find a way to patch the electrical path between the torn halves.
As far as the screen not displaying the full image. That could be deeper damage in the other segments and/or it could be a damaged display assembly depending on how you lifted the display out.
The cables are part of the SIP module which is a costly part, and the display is also costly. I can’t tell you if you need the SIP or the display or both! Sorry ;-{
这个答案有帮助吗?
得分 1
2条评论:
Do the Ribbon Cables break easily or often ?
And yes the screen is damaged, i messed it up when i was separating the screen from the glass :(. The only concern i have , if i buy a new screen, it wont work because the ribbons are damaged. That would be a problem :(
由完成的
Lifting the foil shield is a bit tricky! Preventing stressing or damaging the data ribbons and the connectors takes a bit of care.
Sounds like you may have only damaged the screen. The displays crystal and the screen can't be separated! You need to replace the full assembly.
Only you know if you where too rough with the ribbon cables.
由完成的
添加一条评论
添加你的答案
The Unkownking 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 44
总计 2,064
