跳转到主内容
加入维修社区 - 创建账户
苹果 iPod Touch 系列的第七代产品,于 2019 年 5 月发布。该型号最高配备 256 GB 存储空间和 A10 处理器。型号为 A2178。
How to fix a dropped iPod?
I dropped my Ipod on the ground about an hour ago and it is just the glitchy screen with the lines. How do I fix this techy people? <SOS>
Update: I let it die and then plugged it in and left it alone for a couple hours and it seems to be working fine now. There is still some slight screen flashing but it’s almost unnoticeable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
7条评论
Is the screen flickering still happening?
由完成的
slightly, yes
由完成的
Its possible you loosened the connection on your motherboard. There's no cracks or anything on the screen?
由完成的
Awesome glad to hear! It was totally the big UwU energy that fixed it.
由完成的
okay you have to be one of my favorite people in the entire world
由完成的
显示更多的2条评论
添加一条评论
4个答案
已选择的解决方案
it seemed to have fixed itself, thanks for trying though, it means a lot to me. :>
这个答案有帮助吗?
得分 0
添加一条评论
thank you i would cry if it is broke
这个答案有帮助吗?
得分 0
1条评论:
Thank you SO MUCH for this solution. My iPod was flickering after I dropped it, no matter what I tried. But I turned it off (powered off) and let it rest a few hours and the flickering was fixed. I’m so grateful 🙏🏻 . (Note: one hour was not long enough, was still flickering)
由完成的
添加一条评论
My iPod drop and it won’t come on
这个答案有帮助吗?
得分 0
1条评论:
If you scroll up you’ll see that others have said they let it die and then plugged it in and left it alone for a couple of hours and then turn it on again, this fixed the problem. Their suggestions worked for me. Good luck.
由完成的
添加一条评论
it happens with all 7th gens i wanna believe, when you drop it it kinda like makes the phone panic and renderitself useless like some sad lil puppy on the side of the road. just hold the power,volume, and home button down which resets it and when it powers back on it may flicker but thats only because the LCDs were a bit burned for a bit but will ultimately go back to its normal state within a few hours. it depends on how long the phone was in that state. the longer the phone has the lines the longer the flickering and the lines will appear on the screen. I dont know what causes this but if anyone knows please tell me. im very curious
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
UwU_Person 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 6,067
