跳转到主内容
加入维修社区 - 创建账户
Sega Genesis II 也被称为 Mega Drive II,它是广受欢迎的 Genesis 游戏主机的第二代版本,于 1993 年发布,体积更小、重量更轻。
Sega Genesis Controller port does not work
My Sega Genesis 2 second controller port is not working at all, I’ve tried desoldering and soldering the port a couple times. I’ve also reflowed everything on the back of the board and checked continuity from where the controller plugs in to the resisters just in front of where the pins solder to the motherboard. The weird part is in sonic 2 and 3 it actually does kinda work but then gets stuck going left. What can I do that I haven’t already?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
It’s possible you may have a bent or missing pin. Look inside of the controller slot and if a pin is bet you should be able to bend it back, however if it’s missing I would try to find a new connector and solder it on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Help me 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 39
总计 1,362
