跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Need help identifying a capacitor!
Need help identifying a capacitor! its the one right above the 2F2 inductor on HAC-001 motherboard. Fell of while soldering and couldn’t find it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
post an image from your board and try a little better focus. It is important that we see more of the traces since there maybe variants that would use a different cap. Remember the HAC-001 refers to the model of your Switch and not the motherboard. your motherboard could be something like a HAC-CPU-20
完成的
It says I have a HAC-CPU-10 and added another image, thanks.
完成的
Okay I'd stick with the original plan of a 10uH capacitor. Use a smaller iron and a better tip. Also use more flux and try to control the heat a bit better ;-) Use some desoldering braid and flux to clean the area for the inductor etc.
完成的
添加一条评论
1个答案
已选择的解决方案
1tz_Lowkey  post a picture of what you are looking at. It is hard to follow verbal description. 在已经存在的问题里加入图片
Since these are SMD components essentially you will need to either have the schematic with reference designators or a spare board to measure the values for this component
Update (01/26/2020)
Okay so it is adjacent to the battery charging management IC. It lays between PGround and SYS of that IC. I would use a 10uH capacitor and see what it does. You need to see how it reacts when it charges your battery. bq24193
Of course you get a better answer if anybody has the schematic or can measure it on their motherboard.
这个答案有帮助吗?
得分 1
1条评论:
I added a picture, please help!
完成的
添加一条评论
添加你的答案
1tz_Lowkey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 1,909
