跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
will this upper case fix my problem?
So my friend spilt liquid on her macbook,
it's a white macbook unibody, MC516LL/A ,
Intel® Core 2 Duo Processor 2.4GHz
2GB DDR3-1066 SDRAM
250GB 5,400RPM Hard Drive
13.3" Widescreen Display)
Now half of the keyboard doesn't work anymore (left side and delete key on the other side). wonder if the item you are selling ll fix it if i buy and replace it.
Also is that the right upper case for her macbook?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
so After i swap everything to the new upper case, it won't turn on. i thought maybe the new upper case isn't working so i put everything back to the old upper case but still doesn't wants to turn on. what should i do next?
完成的
添加一条评论
2个答案
已选择的解决方案
You need the Apple Part # 661-5590
MacBook Unibody (A1342) Upper Case
Replace an upper case, keyboard, microphone, left speaker, right speaker, and microphone compatible with the Model A1342 MacBook Unibody Late 2009 to Mid 2010 laptop. Part #661-5396, 661-5590.图片
产品
$49.99
这个答案有帮助吗?
得分 3
添加一条评论
You should put the logicboard in Isopropyl alcohol first, there might be corrosion somewhere
If that doesn't help, you can try, but i will not guarantee anything
If the topcase doesn't work, return it and buy a logicboard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
micheltichu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 828
