跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 个问题 查看全部
Water wont fill in washer.
So my washer will go through the whole cycle but it wont fill with water. Everything else works though. The first problem was it wouldn't stop spewing water. So we changed the water inlet valves. Now it wont let any water through the system. But that's not the weirdest part. The machine will go through the whole cycle of washing just without water. I've seen that there are a couple options to this but I wanted to ask and get a more direct answer. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Abifail howeel the usual issues with the WON’T FILL would be
1. Check water connections to machine.
2. Check for plugged screen in water source.
3. Log valve. See TEST #2, page 9. (attached Tech Sheet)
4. Unplug washer or disconnect power.
5. Check harness connections.
Since your washer etc. goes through the whole program without stopping for errors etc., check the water level sensing components:
TEST #6 Water Level and Pressure Transducer Calibration
This test checks the water level sensing components, and calibrates the pressure sensor.
1. Unplug washer or disconnect power.
2. Access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, page 14.
3. Check hose connection between the pressure transducer on the machine/motor control and the pressure dome attached to the tub. Check to ensure hose is routed correctly in the lower cabinet and not pinched or crimped by the back panel.
4. Plug in washer or reconnect power.
5. Drain the tub until all water has been removed from tub.
6. Remove all clothes from the machine.
7. Calibrate the pressure transducer:
➔See Activation of Manual Diagnostic Test Mode, page 3, and perform steps 1 and 2 until the display shows 00 and the Add A Garment indicator LED is flashing.
➔Press and hold the Cycle Signal button until a single beep sounds, and the display shows to indicate zero calibration has completed.
➔Exit Diagnostic: Manual by pressing STOP or POWER.
8. Select POWER ➔ wash cycle NORMAL ➔ START.
9. Verify that the tub fills to the top of the impeller plate (impeller models) or to a level above the agitator vanes (agitator models), but much lower than the SUPER Load Size water level.
➔If the water level does not fill to this level, replace the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, page 14.
Maytag Bravos Tech Sheet
See if you can give us the complete model number for your washer. Let us know what you find.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Abigail Howell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 3,319
