Fixing LCD Connector on the Screen?
Hello,
i have a MacBook Pro A1398 Late 2013 with no image and no backlight. I discovered that the LCD connector on the Logicboard is working fine with no shorts. However the LCD Connector + Cable on the Screen is blown. It seems that the 2 connectors are identical. Is it possible to replace the Connector on the LCD or is the LCD probably bad from this?
Update (18.01.2020)
Here are 2 Pictures of the Cable and the LCD Connector. The last 3 Pins on the right Side are bad and in the Cable the left ones too. I will buy a LCD Connector and a new cable and try replace them. A new Screen isnt worth the cost (for me)
2条评论
Can you post a few pics of the logic board and cable connectors we can see what's up 在已经存在的问题里加入图片
由 DanJ 完成的
@bulb201 if you know how to solder replace the connector. The panel will most likely be okay.
由 oldturkey03 完成的
