跳转到主内容
Released July 12, 2002. Identified by model number K45SSWH.
33 个问题 查看全部
Did I forget a screw?
Hi,
I replaced the grease in my old KitchenAid K45SS two weeks ago. The machine works and I thought everything is right.
But yesterday, during cleaning the room, I found a small screw on the floor and I don´t know where it came from.
I thought about my KitchenAid repair and now I´m scared if I forgot one screw.
Can someone tell me if the KitchenAid K45SS Classic has such a screw, and if where did i forgot mine? (It is regular check paper so each square is 5mm. the screw has a length of ca. 1cm and the hea is about 6mm)
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The only flat head screws I am finding on this machine are shown in step #4 of this guide:
KitchenAid Classic Mixer K45SSWH Gasket Replacement
这个答案有帮助吗?
得分 3
2条评论:
I’ve watched tons of videos and I could either find no other flathat screw.
I think the screw is gone from some other device….
Thanks for your answer!
完成的
Did you look at the link I posted & step #4. That's where the flat head screws are.
完成的
添加一条评论
添加你的答案
Belial 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 69
