跳转到主内容
KitchenAid Classic Mixer K45SSWH Gasket Replacement
你所需要的
  1. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: 步骤 1 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Motor Housing Cover: 步骤 1 中的图像 2,2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 2 中的图像 1,1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 3 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 3 中的图像 2,2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 4 中的图像 1,1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 5 中的图像 1,1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 6 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 6 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 7 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 8 中的图像 1,1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
  9. KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: 步骤 9 中的图像 1,2 KitchenAid Classic Mixer K45SSWH Gasket Replacement, Gasket: 步骤 9 中的图像 2,2
    • Use a butter knife or putty knife to remove grease from around the gasket.
    • Place grease in motor housing cover.
  10. KitchenAid Classic Mixer K45SSWH Gasket Replacement: 步骤 10 中的图像 1,1
    • Lift the gasket up with your hands or a spuger and remove it.
结论
7等其他人完成本指南。
Joey Gavin
于10/13/14注册
244 声望
撰写一个指南
团队
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G28
4 名成员
创作了22篇指南
2条评论
I got all the way to the last step of replacing the pin when i notice the mixer seemed to lock there in place and not move. What did i do wrong?
Dawn dawn6463@yahoo.com
Dawn Bennett - 回复
Hi there - There is a gasket around the engine part that you can see in step 7. Mine tore when I removed it. Is that a bad thing? I put the machine back together and it seems to work.
RES - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 71
总计 9,355
