跳转到主内容
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
Why is my device not charghing?
So my tablet is plugged in but is still not charghing.My biggest problem it’s that it shutted down before I could try to solve the problem from the settings.Can someone please help me to figure out what it’s going on?Should I buy a new charger?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@secretgirl I would not just go ahead and replace the charger just yet. Measure the output of the charger with a multimeter and see if it has the required voltage. If so, not reason to replace it. If is does not then you replace it. After the charger you will have to check the charging port. Check for debris, corrosion, bend pins etc. Clean it with a few drops of 90%+ isopropyl alcohol and a few puffs of canned air. If that does not resolve it you will have to take your Surface apart. There you would need to check your charging port connector as well as the power management IC. Even so this is not a guide, it’ll show you what you are up against. So, start by checking the charger first.
Microsoft Surface Pro 6拆解
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Secret Girl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 325
