Stuck in a boot loop
My computer is stuck in a boot loop. As soon as the battery is plugged in the fan turns on, computer chimes, fans stops, fan on, chime, and so on. The screen remains black throughout. I have replaced the logic board, RAM, and battery all without any improvement. Resetting the SMC and PRAM did not make any difference. If I unplug the ribbon cable from the keyboard, plugging the battery in does not start the fan or the chime, however with the cable unplugged I can’t turn on the computer at all. What do I do next?
6条评论
What happened at the start of this? Did you have a liquid spill? Or drop, bang your system?
由 DanJ 完成的
Does it work OK without battery? as @danj asked what happened?
由 Markus2 完成的
The computer was turned off at night, I tried to turn it on the next day and this was the result. No drops or spills that I am aware of. It does not work with the battery disconnected either.
@carl2
由 Tyler 完成的
What color is the MagSafe chargers LED Amber or Green? If Ambor let it charger for a good 8 hours did it get to Green?
由 DanJ 完成的
The charger light did change to green after several hours charging. Boot loop solved with new keyboard, but the screen does not come on at all now.
由 Tyler 完成的
显示更多的1条评论
