跳转到主内容
加入维修社区 - 创建账户
Repair for cars and trucks manufactured by German automaker Mercedes-Benz.
Rear headrest deployed. How do I get them down
2001 CLK Convertible my rear headrest deployed. How do I get them down
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
How do you get them back up I heard the noise on the button but nothing move thanks
完成的
I have a 2007 s550 and the same thing happens with my car……. I hear a click but head rest stays up🤷🏾‍♂️
完成的
Mercedes benz ml350 no change ger at hot car
完成的
How can I manually lower the rear headrests in my 2004 Mercedes FLK 500?
完成的
添加一条评论
1个答案
已选择的解决方案
richard morris check this video and see if it works for your model as well. Or you can try what works for the 2000 CLK . You can reset them with the button that you normally use to adjust your headrest. To reset the rear headrest, which MB calls a roll bar, press the upper half of the button and hold it for 8 seconds until you hear the mechanism engage, then press the lower half of the button to lower the headrests.
Update (01/09/2020)
这个答案有帮助吗?
得分 3
3条评论:
Thanks oldturkey03 your Vedio is for a 2005. My car is a 2001. I tried pushing the button to the left of flasher and it did nothing
完成的
@richard morris I added the instructions from the 2001 CLK owners manual.
完成的
Hello. I have 2004 clk 500 that I cannot figure out how to lower the rear head rest. this car does not have the roll bar button thanks.
完成的
添加一条评论
添加你的答案
richard morris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 48
总计 11,924
