跳转到主内容
Repair information for Sharp televisions.
105 个问题 查看全部
Yellowish discoloration on LCD TV
My Sharp Aquos LCD tv model LC-C6554U has some vertically oriented oval-shaped yellowish discolorations in the upper left corner, upper right corner, and upper middle. The rest of the picture is perfect and these areas are only visible with a light image color, such as sky or snow. I’m hoping this is repairable as the rest of the TV functions perfectly. Any thoughts? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Rick Dortch could be a backlight issue as well as other things. Yellowing can be caused by bad backlight LED’s and sometimes the diffuser caps can fall off and change the appearance as well Of course there is always a possibility of a bad panel etc. We would need to see what you see. Post some good pictures with your QUESTION. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
3条评论:
Looks like the yellowing is following the backlight arrays. You would have to disassemble the panel to take a look and possibly replace the backlight LED strips. Of course there is always a chance the yellowing is on the diffuser sheets (unlikely) and you will find out when you disassemble the panel. It's a bit of work and there is always a risk of breaking the panel with to much flex etc. I think I would just try and live with it until there is absolutely no other way.
完成的
Thank you oldturkey03, I just added some photos. The yellowish discoloring shows up best with the tv set to “antenna”…there is no antenna connected. It’s very light and sometimes hard to see with a standard image unless the background is light colored. I put one photo with no markings and one with rough red outlines around the areas. Thanks again.
完成的
I recently changed backlight LED from a local repair shop and from that day my panel started looking yellowish tint like you see when you set your mobile phone to night mode i wonder if backlight that guy installed were bad
完成的
添加一条评论
添加你的答案
Rick Dortch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 79
总计 9,136
