跳转到主内容
The ASUS ZenBook, which can be identified by the model number UX330U, was released in March of 2017. The UX330U is also referred to as the UX330UA in some regions. The ZenBook uses Windows 10 and features up to 12 hours of battery life, a QHD+ Display, and a lightweight and slim profile.
9 个问题 查看全部
UX430U wont boot up unless hard rebooted with battery disconnected
Recently, I dropped a few drops of water around the power key of my laptop. It did not show any issues then, but after shutting it down, it did not boot up. It shows as charging if plugged in though.
Taking it to folks at geekbench resulted in a temporary solution where hard rebooting with battery removed (and power attached) leads to the laptop turning on. Now the laptop needs to hard booted that way or else it wont boot up.
Any suggestions what might have gone wrong
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@pscoe2 possible that the battery is shortening it out. Replace the battery first. If that does not work you have a short circuit on the charging circuitry. You will need the schematics for your motherboard as well as the board view for it to a. check on it and b. possibly repair it if you have knowledge and tools for board level repairs.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Puneet Singhal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 532
