跳转到主内容
加入维修社区 - 创建账户
MacBook Air won't turn on. Charger stays orange.
This is WEIRD!
I installed a fresh clean MacOS High Sierra on my MBA 2015. Worked fine.
I then turned the mac off and left it for about a month.
I came back to it just the other day, and it won't turn on.
Plugged in charger - green light at first, then red light.
Ok, I thought it'll charge a bit and turn on (even though I do remember turning the mac off before I left for my break).
Came back after 30 minutes. Still won't turn on.
Thought it was the charger. Plugged in another charger (which works for sure). Same thing.
Weird.
Did all the reset BS that I found online (SMC, SM-this, SM-that, PM, PR, all that stuff). Nothing.
Opened it up for inspection. Looks like it's brand new (seriously - I take care of my stuff like crazy! A bit OCD on these things).
Disconnected battery and reconnected it. NOTHING.
What gives?
Anyone here has a clue?
Here are some pics:
https://imgur.com/uLsVAtI
https://imgur.com/Bq8cob3
https://imgur.com/G3A3BVf
https://imgur.com/a/MEAYUBB
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Thanks @arbaman
Battery death my be the case. But a Macbook Air 2015 won’t boot without a battery? Because I did disconnect the battery and tried turning it on, but it won’t.
The condition of the board and internals are so new-looking, that I am still refusing to declare this machine dead.
Perhaps this model of MBA won’t turn on without a battery connected? I read somewhere that some of the models indeed won’t turn on without battery connected to them.
完成的
@wdadjkalsdjlk Your Mac would work normally without a battery, hence my advice to disconnect it. Fact that it doesn't start even without it, points to other hardware faults.
完成的
@arbaman Thank you. Any other suggestions of action? Something else that I can do on my own?
完成的
@wdadjkalsdjlk I'm not sure I'd feel comfortable in suggesting you to buy random parts to see how it goes or buying a multimeter and get into schematic diagrams to start probing power and data lines. However, these are the only two possible troubleshooting paths I'm aware of.
完成的
you are very much correct. not to mention it's way above my paygrade. I am just very frustrated because I needed this laptop for school and I am so broke right now. I guess I will have to let it go.
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
With Mac unused and unplugged for a full month, what might have happened is that battery reached its heaven and went bad and unable to take charge any longer. First step would be to try and disconnect the battery and see if that gives any change and Mac would be able to start on its own when plugging in the magsafe. If it starts without the battery then a battery replacement may probably solve all issues, otherwise we get into machine hardware failure that would need more or less blindfolded parts replacements to progress any further with troubleshooting.
这个答案有帮助吗?
得分 4
1条评论:
When you disconnect the battery and magsafe adapter, press and hold the power on button for ten seconds. Then reconnect the battery and mag-safe. This should give you a spontaneous reboot.
完成的
添加一条评论
添加你的答案
dashndjash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 30
总计 7,422
