跳转到主内容
The Dell Inspiron 910 Laptop was released in 2008 as part of the Dell Mini Series of small, portable laptops.
Trying to Factory reset Dell 910 mini
Tried tapping f8, there is no f11,&no disk and need to factory reset please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
@angelsattic depends on which revision your BIOS is. Inspiron Mini 9 do now have F11 / F12 functionality (starting from bios revision A01). They have been mapped to:
Fn + Z = F11
Fn + X = F12
完成的
I dont have f11 and f12 what i do
完成的
My buddy gave me a dell inspiron 910 mini and it has all kinds of stuff on it that I am trying to delete and can't figure out how. can anyone help me
完成的
添加一条评论
2个答案
最有帮助的答案
@angelsattic you are not telling us why you need a “factory reset”. It sounds like you need to reinstall your OS. If you can still access your system try to search for a file named “WINNT32.EXE” and double click on that. It should reinstall your OS. If you can’t, you may have to invest in an external CD drive and reinstall your Windows OS that way. Of course you will have to have a restore disk or an complete operating system disk.
这个答案有帮助吗?
得分 2
添加一条评论
Hi @angelsattic
had you tried F12 key?
If so and cannot load … maybe factory recovery partition or image is corrupted.
What OS does it comes with?
If it is Windows 7 and higher, I would suggest you to make a windows10 USB installer tool from microsoft website.
https://www.microsoft.com/en-au/software...
you need to use another PC / or if windows are still able to boot, to create this.
some tools @ F12 Menu I would recommend you to proceed is to do a full system check or diagnostic for any possible issues on your laptop, reason this is to check on your hard disk to ensure it is healthy.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AngelsAttic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 1,597
