Display works and doesnt work
My iMac display goes black a lot but if you were to shine your phone light at the screen you can actually still see the stuff on the scree and changing the dim does nothing.
Somedays it works and other weeks the backlight wont come on. It originally started doing this after an update about a year ago. It would sometimes start up in safe mode for a bit and then go black again. It’s never been touched internally and pretty much barely used as it happened a few months after I bought it in 2018. Not sure what exactly is going on, but feel like it’s maybe a software issue as the backlight will work sometimes.
Update (01/01/2020)
It will reboot when I start up holding down Option key. But, then after a couple minutes the backlight just goes completely out.
It goes out no matter how I get it to power on. Then sometimes i’ll leave it on with no backlight and then hours later the backlight will go on. I’ve tried disc repair.
Everything I can think of and google and the backlight won’t stay on.
I got it to work about a month ago for a week straight with no issues and then it went back to having the backlight issue.
Can’t find much researching this issue as it doesn’t seem like a very known issue. Maybe at this point its best to take a it to a repair shop if it can even be fixed.
1条评论
Before you throw the towel in how about running the onboard diagnostics. Restart your system and press the D key
Reference: Mac startup key combinations
Did you get any error codes?
由 Dan 完成的
