跳转到主内容
加入维修社区 - 创建账户
Mr. Coffee TF6 是一款由 Sunbeam Products 生产并以 Mr. Coffee 商标销售的 5 杯容量开关式咖啡机。
What thermostat does it use?
I have the TF5, listed in the description for this repair as (almost?) identical to the TF6. It looks like the thermostat is NG, it ohms out as open. I haven’t been able to find the replacement part number.
Also, it doesn’t look like the components attached to it (fuse on one tab, wire on the other) are soldered, how are they attached? Can regular solder be used when replacing the thermostat, or should crimps be used? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
I opened up my Mr. Coffee, it is a different model and I can’t see much except a symbol or possible acronym on the one side of the thermal switch/thermostat and the other side is sort of locked in against the heater tube and I wasn’t ready to pull it all apart. Sorry but is “NG” slang for No Good or is that a marking on the thermal switch? Can you provide any marking info or photo of the part?
由完成的
@drmdolfan - First, in this case NG=no good. Second, my bad., maybe I should have removed it and read the part number instead of just Googling hoping to find a repair parts list :-).
The markings are:
KSD301-G
125V 16A
145
Apparently 'KSD301' (with or without the -G) does not infer temperature. And, I admit, I'm more than a little uncertain if the 145 is in Fahrenheit or Celsius. It's pretty chilly for brewing coffee in Fahrenheit, but maybe it's just a 'this is the temp this area gets to when the rest is at normal operating temperature'. But in Celsius it's pretty hot. I found a website that shows what happens to a coffee maker when the thermostat is bypassed (https://www.electrical-forensics.com/Cof...) and it's not pretty. So putting in a thermostat with too high a cut off is something I would really like to avoid. If you can shed some light on this it would be appreciated!
Thanks,
Jon
由完成的
Added photo of thermostat to the original post.
It may be that the -G means ceramic body (which mine has).
It looks to be 'Normal' type (this apparently refers to the body size), aluminum end, with 24mm hole spacing on the bracket.
If now I could only be sure what scale the temperature spec is in. :-)
由完成的
Units are in Celsius.
145 Fahrenheit wouldn't boil water.
the thermostat not only has to support the amperage of the heating element.
the thermostat must switch open over the boiling point of water and under the melting point of the appliance. it would be a bit safer with a switch around ~120C but would result in slower water throughput.
The plastic (polypropylene in this case) would melt at ~170C-200C
由完成的
添加一条评论
1个答案
已选择的解决方案
@jon2001, I found the data sheet online at the following link: https://www.calcoelectric.com/images/pdf...
You should be able to get an exact replacement or equivalent rated device from electronics / parts catalogs. Suggest using crimp type wire lugs for this repair. Let me know if you need any additional help.
这个答案有帮助吗?
得分 3
8条评论:
Thanks, found the same one myself! Do you know the answer to whether the 145 on my thermostat is in F or C?
由完成的
Appears to be in Celsius since all values on the data sheet are in degrees C. The “G” apparently refers to an auto reset.
由完成的
Hi @drmdolfan ,
Would a thermostat for a coffee maker be set that far past boiling point i.e. 145 C (superheated steam?) whereas 145 F = ~63 C which may be just above the preferred temp for coffee brewing?
Unless of course it is used as a safety cut out in a boil dry situation
Just thinking
由完成的
Hi @jayeff ,
There is an excellent article linked above that describes the various purposes of the thermostat and thermal cutouts of the coffee makers and why they are needed! Take a look and you’ll see these devices are rated in degrees C.
由完成的
Hi @drmdolfan ,
Thanks
由完成的
显示更多的3条评论
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 5,044
