跳转到主内容
加入维修社区 - 创建账户
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Display data cable cleaning?
Hi guys!
I recently bought a non-working Macbook unibody 2.0 GHZ A1278. When i opened up the back it looks like i minor liquid spill right about the magsafe board is. I am about to order a completely new logic board and DC-IN board to try and fix the problem (the macbook doesn't boot up at all).
It seems that the connector for the display data cable and the very end of that same cable has also been affected by the liquid. The connector and cable have no errosion or anything but they seem a bit "dirty". The connector (where the cable connects to the logicboard) will of course be a new one when my logic board arrives but my question is: how do i best clean the connectors of the display data cable?
Should i use alchohol or some sort of mixture? I have seen that the display data cable can be bought separetly but is it simple to replace?
Thanks for your help in advance!
Best regard
Olof from Sweden
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Here's what we recommend for liquid damage repair: Electronics Water Damage
这个答案有帮助吗?
得分 1
添加一条评论
Thank you so much!
How about the lvds cable? Is it hard to replace if all else fail.
Best regards
Olof
这个答案有帮助吗?
得分 0
添加一条评论
hi
Lvds cables with different width and timely replacement must be exactly the same principleBut if you do not replace it. Can by a small brush and a little alcohol mixed with "tinner "wash carefully and give its edges with a dry cloth(tinner) is "paint solver" buy tool shop .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Olof 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 1,594
