跳转到主内容
加入维修社区 - 创建账户
Motorola Moto Z4 来自 Motorola 的 Moto 系列,型号为 XT1980-3 和 XT1980-4。它还支持 5G 网络。
Screen replacement tools ands part
Cracked screen I need parts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
6条评论
InjuredGadgets.com
由完成的 分享
So where is the guide to fix it?
由完成的 分享
Could not find any guides there.
由完成的 分享
@ruppertj It opens up just like the Z3, but the ribbon is on the right side. I would recommend disconnecting the battery first.
由完成的 分享
Well this was a day late and a dollar short, It would have been helpful if the cause of the screen separating from the body was caused by the battery expanding from gas build up. This did not effect the battery performance but it surly is the cause of the screen separation. This should be noted as the main cause of screen separation and the screen cannot be replaced until the battery is replaced. I wasted two screen replacement kits Z2-Force and Z4 because of the batteries had expanded. This was the cause in my Z2 and Z4 screens to separate.
由完成的 分享
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
Hi,
There are suppliers online.
Just search for Moto Z4 LCD part with tools to get results.
Here are just two suppliers found on a quick search
example 1
example 2
这个答案有帮助吗?
得分 3
1条评论:
InjuredGadgets has the screen as well but I would get the Genuine and not the other cheaper one from them.
由完成的 分享
添加一条评论
I think iFixit sells a wide range of tools and replacement parts, if that’s what you mean.
这个答案有帮助吗?
得分 1
1条评论:
If you read carefully no that not what I mean ...moto z4 is the title
Screen Replacements tools and parts ..that the subject...and finally
Cracked screen ,,I need part that's the message..
由完成的 分享
添加一条评论
Both of those examples are LCD screens which are for the cheaper Moto z4 play. The original Moto z4 has an OLED screen. Make sure to look out for this because as far as I've researched, they are not compatible with each other.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alexandre Domon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 3,702
