跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
monitor won't stay illuminated unless I open it very wide or narrow
When I am using my MacBook white 2008 with battery or ac (not a power issue), the monitor needs to be in one or 2 very specific positions in order to make it light up. I think it might be a switch in the hinge or something. Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
sounds to me like it's your inverter cable. see this guide for replacing it.
MacBook Core 2 Duo Inverter Cable Replacement
as for teh cable itself, please provide us with the last 3 digits of your serial number and we will be able to provide you with the exact part number as there are a few versions of the cable.
这个答案有帮助吗?
得分 1
添加一条评论
I agree with pierrej, if you can still dimly see the desktop when it goes out. Here's my guide on that: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
If you can't see the desktop, you will most likely need to replace the Display Data Cable. We need that serial number.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 357
