跳转到主内容
加入维修社区 - 创建账户
VG248QE 是 Asus 于 2013 年 1 月发布的一款 24 英寸游戏显示器。其刷新率为 144 Hz,并支持 Nvidia 3D Vision。
How to make it run on 12V
I’d like to connect it to my Van electric system which runs on 12V, without having to use an inverter (since it kills the battery life). Any suggestion or recomendation will be most appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
There is no other way than 110VAC to power this monitor. You could look for a monitor that has an external power adapter and coax power input.
这个答案有帮助吗?
得分 0
添加一条评论
I know that, yes, an inverter would take more or less an extra 30 watts when running, but unless you are running the engine, it doesn’t matter which way you power the monitor, the monitor’s watts/consumption will be the same. Car/Van batteries are not designed to be drained in this fashion, with the engine off. They will be ruined if they are deep cycled. Now, if you have deep cycle batteries or are running the engine, then an inverter is the way to go because battery life will not suffer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gon Arada 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 618
