跳转到主内容
加入维修社区 - 创建账户
Asus K53E-BBR3 是一款时尚的 15.6 英寸金属笔记本电脑,于 2011 年推出,适用于日常使用。
DC power jack loose
Can anyone helpme, this just occured today. When i was charging my laptop it suddenly not charging so i push and it work only if i pushed it. After searching on the internet it says that my laptop dc jack has come loose, can anyone help what should i do with this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the power jack has come loose, you need a soldering iron to reattach it to the motherboard. It needs to be a good one, the cheap ones don’t get a good enough temperature to get rid of the old solder. If the power jack itself is damaged, you can usually buy a replacement power jack online with the correct make and model number of the laptop.
If you’re not that good with a soldering iron, or don’t have one, then you can disassemble the laptop and take the motherboard and power jack to a computer repair shop and they should be able to do it. Most of the time is taken up by the disassembly as it can be a bit persnickety, but instructions are available online and on YouYube for many different models.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bodybody 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 817
