跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
I have a Blue screen and cant see anykind of menu or anything else
I have an RCA LED46C45RQ LCD FULL HD FLAT SCREEN. I have power, volume, remote works and changes channels, but, I have a Blue screen and cant see anykind of menu or anything else to suggeat what I need to do ! I have looked at MANY online suggestions and nothing has worked. I know that the tv is still good but, I cant get a NEW suggestion on what to try ! I have also done some BLIND tries ! I dont know where the screen settings are going or when to push the "Ok" button or to push the right or left side buttons. PLEASE HELP !!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Michael James Vasger  since you only have the blue screen and no menu or any other input, check the main board. Remove the cover and check the board for obviously damaged components. “MANY online suggestions and nothing has worked “ if you let us know what you have tried then we do not have to repeat things that you already know wont work.
这个答案有帮助吗?
得分 3
4条评论:
I had taken the back off of it and it has lighting but can't get a screen to show the shows or channels
完成的
@Michael James Vasger what make and model is your TV? You took the back cover off and seen the light? Backlight? Give us more information so we can try and help you out. What does your TV do exactly? What have you checked?
完成的
Thanks for getting back to me. I have had the tv sitting for a while to see if I can get it fixed ! I have power but unable to get a tv channel or to even see the menu. I have the remote but I'm unable to see if I am switching channels !! It's a 43" RCA flat screen TV. I would really appreciate any suggestions that you or anyone may have ! Thanks again !!
完成的
@Michael James Vasger do you have a model number for it? Do you see anything or is it just plain blue screen?
完成的
添加一条评论
添加你的答案
Michael James Vasger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 305
