跳转到主内容
发布于2017年8月,Galaxy Note 8是被召回的 Galaxy Note 7的接班人。Note 8于2017年9月向公众开放购买。
148 个问题 查看全部
Black screen, no drop damage
My note 8 screen suddenly stopped working, no drops or known damage of any kind. Just a totally black screen but everything else seems to work, light blinks, it rings when you call, everything. A repair shop that was planning to replace the screen said the screen is ok but the screen power chip is bad. Does anyone know of this is on the logic board or daughterboard? Also, if i replace the logic board, will i lose my data?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Brady Martin “if i replace the logic board, will i lose my data “ yes you will. Your data is stored on a memory IC which is part of your logic board. Not sure which “power chip “ the person you took it to is referring to. U900 is the display PMIC which, in principle could qualify what that person is suspecting. It is on the logic board. I’d suggest you go ahead and follow the troubleshooting as outlined here
这个答案有帮助吗?
得分 3
1条评论:
Thanks so much for the helpful response. I'm just getting into component level repair, so this should help a lot. I'll give it a try
完成的
添加一条评论
添加你的答案
Brady Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 222
