LG washer tub leaning backwards and seal is crumpled WM4270HVA
So I bought this washer used. I don’t have any insight into its history. But I took the top off and it looks pretty clean on the inside. However, It has this weird issue that I cannot for the life of me figure out.
If you look into the washer the seal between the tub and front panel looks crumpled. After taking the top of the washer off I was able to grab the tub and pull the top part of the tub toward me. When I do that I can get the seal to be mostly uncrumpled. If I pull the top of the tub toward the front of the washer and I reach inside the door and push the bottom of the tub slightly away from the door. The seal starts to look much better.
The 2 springs on the sides look fine but I’m not sure what to look at next as I can’t see anything else that should cause the tub to sit differently.
Help, please.
1条评论
Jeff Hicken post some pictures of what you are seeing with your Question. That way we can see what you see and we are all in the same book. 在已经存在的问题里加入图片
由 oldturkey03 完成的
