跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 flashes weird Pink color and then restarts every 2 minutes
So I got this iPhone off Ebay for 100$ and it was water damaged. I cleaned it with isopropyl alcohol and it powered on! When it is being used for more than 2 Minutes it just flashed a weird pink sphere (looks like a blurry face) and then just showed the Apple logo and restarted.
Any help is apreciated!
Here is the link to the Video:
https://cdn.discordapp.com/attachments/2...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Its already fixed I just cleaned it with more isopropyl alcohol and it just works fine now
这个答案有帮助吗?
得分 0
1条评论:
Lucky man, hope it lasts :)
完成的
添加一条评论
最有帮助的答案
Liquid damage probably hit the SoC itself. There’s not much you can do on your own to fix it and a Pro would be too expensive to be a reasonable alternative, providing you’d find one who wants to take the headache to work on liquid damage for a stable fix and not just for data recovery. Buying liquid damaged devices is a pretty bad idea, even for a capable technician.
这个答案有帮助吗?
得分 2
1条评论:
Friends on discord told me it has to do with the battery and the power line
since the battery doesnt wanna charge and 3utools doenst show any battery data
完成的
添加一条评论
添加你的答案
Radxio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
