跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
What wattage does this iMac’s speakers use from the motherboard?
I’m converting iMac Late 2009 speakers into regular headphone jack speakers by soliciting the cables and I connected them right where there is no distortion and they sound good but the volume is low and doesn’t go higher. I think this is because there is nothing powering the amplifier inside the speaker so I need to connect a power source but I need to know what is the wattage these speakers use?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Curious to know how this project turned out for you, as I am attempting something similar with a pair of 2013 iMac speakers and would appreciate any insight!
完成的
it turned out good! i just used https://www.parts-express.com/21-hi-fi-c... and it worked like a charm and it kept the woofer and tweeters working together already :))
完成的
@Teddy Glad to hear it! I know the 2013 speakers are a little different, but hearing that your version worked gives me hope. Any specific snags to look out for? Or is it pretty much just plug and play? I was considering getting a crossover to separate the tweeters, but maybe it's not worth it!
完成的
for me it was just splicing the speaker cables into the amplifier and it was just plug and play, very easy
完成的
添加一条评论
3个答案
已选择的解决方案
Teddy if you like those speakers you do not want them connected as previously described by you. The iMac where those speakers are coming from use a Woofer and a Tweeter amplifier. Your speaker separates the tweeter and the woofer in the plastic case. Each set of white/black cables is for the separate speaker. Connected one set of black and white to power will most certainly put an end to either one of those. If you are wanting to use the amp listed in the preceding answer, connect the two white and the two black from each speaker housing to either L or R. L- (WhiteX2) L+(BlackX2) and same for the right.
Here are the values for the amplifiers
TWEETER SPEAKER AMPLIFIER
AMP VOUT = 7.355VRMS
GAIN = -4.8(20K/17.4K)
MAX9736B APN:353S2042
POUT = 6.76 W INTO 8 OHMS @ 1% THD+N
WOOFER SPEAKER AMPLIFIER
RIN = 17.4 OHMS
FC = 19.5 HZ
这个答案有帮助吗?
得分 4
2条评论:
@oldturkey03 I don’t suppose there’s any chance you know the specs of the 2013 27” iMac speakers, is there? I’m attempting the same kind of project (though I’m keeping mine in the iMac casing and turning it into an external display). I don’t know anything about audio, but my research thus far has led me to believe I need an amplifier at the very least, and a crossover if I want to get both the woofers and the tweeters working together. Any help you can provide would be most appreciated!
完成的
Regarding this line:
Does this mean that each speaker amplifier is 6.76 WATTS?
If so, would that mean that each combo speaker (tweeter + woofer) is 13.52 watts?
If that is also true, then I’d need an amplifier that supplied more than 27-28 watts (probable 50watts) to drive both of these.
Are those assumptions correct? And if not, what have I gotten wrong. I would be super grateful for some help here! Thank you!
完成的
添加一条评论
You need more than a power unit you need an amplifier unit! This will get you the volume.
2.1 Hi-Fi Class D Audio Amplifier Board 2 x 15W + 30W 10-18 VDC
这个答案有帮助吗?
得分 2
2条评论:
Where would I connect the spliced power cables from the speakers into that board?
完成的
each speaker has two white and two black cables, so i should put one white and one black from each speaker into the - and + for R and L. And then the other white and black into VDD and GRD.
完成的
添加一条评论
Did this amp work for you Teddy? I’'m trying to do the same
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Teddy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 59
总计 3,809
