跳转到主内容
加入维修社区 - 创建账户
Alcatel One Touch Idol 3 配备 5.5 英寸、1080 x 1920 分辨率显示屏,搭载 1.5 GHz 处理器。于 2015 年 6 月发布。型号为 6045Y、6045K、6045O、6045I。
Text but not call out.
The signal strength in my area is not strong enough to make calls. The phone works fine when a decent signal is present. I’m OK with this for now since I have a landline. I can, however, send texts when I’m in this low signal area. How is it I can send texts but not make a call?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
[ SMS is a standardized communication protocol that enables devices to exchange short text messages and was defined as part of the 1985 GSM protocol. Originally it was designed to "fit in between" existing signalling protocols which is why SMS length is limited to 160 seven-bit characters. It was subsequently codified into the SMPP signalling protocol that transmits SMS and is limited to precisely 140 bytes (or 1120 bits). ]
You need less that a second of stable signal to send one SMS, but one call needs a stable connection to start a session.
这个答案有帮助吗?
得分 2
1条评论:
Thank you...
完成的
添加一条评论
添加你的答案
ruko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 163
