跳转到主内容
加入维修社区 - 创建账户
Samsung Series 3 系列电脑中的 NP300E5C-A09US 是一款 15 英寸笔记本电脑,屏幕分辨率为 1366x768。对于任何追求轻便而又性能强劲的便携式电脑的用户来说,它都是一个绝佳的选择。
No BIOS or OS
I have a old Samsung NP300E5X-A0ANG (which a model number IFIXIT didn't have)
I had Linux Ubuntu installed on it which for some reason stopped working so i decided to wipe the drive and start fresh but i come to realize it no longer has BIOS at all
So i have no way of getting into a one time boot menu no idea what button(s) i have use to flash an old .bin file i apparently had in Google drive (i have a account were i only put drivers and firmware etc. On it in case i ever need it)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
I think you are saying that you can not access the bios…it must have a bios if it was booting but perhaps the access to the bios is corrupted? I would take the unit apart (look for tear down videos of similar models or search for some instructions…I had to do that with my obsolete and uncommon laptop and somehow found enough info). You’ll need to locate the CR2032 or similar bios battery holder on the motherboard and replace the battery.
这个答案有帮助吗?
得分 0
1条评论:
Tried that didn't work and yes what i mean is i cant access a Bios anymore
由完成的 分享
添加一条评论
The problem is caused by UEFI boot after installing Debian Linux. The Samsung BIOS is faulty by default and if I know well it is not yet fixed by the manufacturer. I had the same problem. The only solution is BIOS Flash. It can be done if you buy a programmer like CH341A. There is a great tutorial how to make it: ++https://jensd.be/980/linux/bios-or-spi-p...
这个答案有帮助吗?
得分 0
添加一条评论
Hi! I have an NP300E5C, ita version. And yeah, same issue. After some long researches, it came out that installing linux on these laptops, corrupts the NVRAM. For this reason, the bios becomes not accessible anymore, and the os doesn't boot anymore. Other drives won't boot too. Try to enter the boot menu pressing some random F keys. If this doesn't work, unfortunately you can fix only by replacing the bios chip (costs around 15€ on ebay, not really expensive)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Tahir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 2,010
