跳转到主内容
加入维修社区 - 创建账户
适用于配备 GSM 3G 蜂窝网络(AT&T)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。采用双核处理器。于 2011 年 3 月发布。通过型号 A1396 进行识别。维修时需要使用加热工具并小心撬开。
iPad Mini 2 only powers up on charge but bootloops and then gets stuck
My iPad is on iOS 10.3.3. I cracked he screen and the battery etc was disconnected for a week now. Popped the new lcd and digitiser in and tried switching it on but the device did not switch on. I then plugged it into a wall adapter and saw the Apple logo (finally). But then the device started bootlooping on the Apple logo. I hard reset the device and eventually I was led to just a blank screen. I left it on charge over night with no luck. Whenever I disconnect the charger the device switches off and does not switch on again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Latif Abdul  all of this sounds like a bad battery. Replace the battery with a new one and re-evaluate. If nothing else it will provide you with a known-well starting point should further troubleshooting become necessary
GSM 版iPad 2电池更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Latif Abdul 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 253
