跳转到主内容
The Lenovo G50-70 can be identified by model information printed on the bottom (model name 20351), or on sticker next to track pad. This laptop has a 15.6 inch screen with Dolby audio. Manufacturing began in 2014.
12 个问题 查看全部
it start but mouse keyboard and screen are not
I bought this pc in 2014 and I used for less than one year because I bought another one.
So I saved the first one in a box in safe place until yesterday
I get it and try to turn on but I see that the mouse, keyboard and screen are not worked and the fun is work
and also when I put or remove the charger the pc make a beep.
I remember that I use this pc two years ago just for 30 minutes to get some files and folder, it’s worked normally
I replace the cimos battery with a new one but it’s the same.
So, what’s the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
So.Sona this "also when I put or remove the charger the pc make a beep” could be because your battery is discharged below the threshold of accepting a charge. So get a new battery first. Attach an external monitor and see if that displays anything. If so you know you are having issues with the display. If not then you need to try to get into the BIOS. Sometimes a bad hard drive can also be the cause for this. Download the service manual from here
这个答案有帮助吗?
得分 0
添加一条评论
I forget to tell you that when I put the charger pc do a beep and turn on automatically
I remove the battery and put charger, it’s same (pc do a beep and turn on automatically )
and I forget something about battery light
yesterday it was red which means is very low, so I put it for long time and it is now white which means the battery is full or more than 20% (I think it’s charging)
I can see that the battery is not the problem()
I have thinkpad T430
can I use this battery to test the second pc
any other idea?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
So. Sona 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 98
