跳转到主内容
电脑显示器维修。
505 个问题 查看全部
Cloudy dust like , spreading slowly inside my Pc Monitor
(illustration) at beginning
some sauce of my Meals dropped onto here, maybe some went inside thru the “border line” on topside?
(actual) now
(actual) now
(actual) now
Turn LCD monitor off completely , complete black like normal
Turn LCD monitor on , Turn feature : “MagicAngle” off to see them (dust like dots) more clearly
(Cannot be seen in white background, seen clearly in black background)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
11条评论
Hi,
What is the make and model number of the monitor?
Has the monitor gotten wet at all or is it in a very humid environment?
完成的
The room is always in dry and a bit hot ,air flow & ventilation a bit bad there. But the heat from CPU computer add up in that room. I think it's not wet at all... Or humid enviromental.
Aha! I just remember , there was once ,
One or two drops cooked oil from my Meals spilled onto the top of monitor and some oil go down to the front part of monitor ,not inside(which we stare everyday). I wiped them up ASAP with Dry tissue+Alcohol
i think a little oil go down inside through the gap of the monitor's thin casing on top side?
完成的
@mymobilelegendss what make and model is your monitor?
完成的
@oldturkey03 It's some sort of Samsung. I had a hunch based on the design and it's confirmed in the photos (2nd photo). It looks like a 24" 1080p to me.
完成的
@nick Yup, but some sort of Samsung really doesn't help us out here
完成的
显示更多的6条评论
添加一条评论
2个答案
已选择的解决方案
That’s usually due to layer delamination due to a panel defect, especially if it spreads over time. The problem is you can’t fix this without replacing the entire panel. Unless the panel is fine and it just needs to be cleaned out internally (which is still a risk, but it’s doable if you’re careful), it’s usually unrepairable.
The problem is with most 1st party panel manufacturers, it’s typically cheaper to replace the monitor as a unit due to the cost of the actual panel itself, and this is usually the case with LG and Samsung as they make their own panels. That being said, sometimes Samsung doesn’t use their own and uses a 3rd party one, so they also are sometimes cheap to salvage - it’s usually AUO if this happens. However, unless you can find a cheap panel, it’s usually better to replace the monitor as a unit since it’s almost always a lose-lose proposition cost wise. Acer, AOC and Dell are not panel manufacturers, so you can somethimes get off lucky with those types of monitor brands.
Make sure you reset the panel hours as well if you find one that’s brand new. On Samsung, set the brightness and contrast to 0, exit the adjustment mode (if needed - not always required) and hold down input. For joystick control, navigate to input and hold it down until the service menu comes up. Hold menu on panel hours for 3 seconds and it resets.
You’re one of the unlucky ones :-(. This uses a Samsung LTM panel (LTM185AT01). Since this doesn’t look like one where AUO panels are a backup plan for short internal supply, the panel likely won’t be cheap when you can get something newer with a more current port configuration (or at least a DVI/VGA with a DHI->HDMI adapter included in the box - which Samsung sometimes does with their older designs to cover for the fact many new GPUs and towers no longer use DVI). The service manual can be found here (translation required). It’s also not readily available new, so you may need to get a used one on eBay with minor issues at a discount you can accept, or at least find the AUO equivalent part if multiple panels were used and try your luck.
这个答案有帮助吗?
得分 4
2条评论:
This happened to my wife's Viewsonic monitor, now it happened to my Samsung Lapfit LD-190G.
I contacted Samsung tech but they said, they'll have to get back to me.
Any idea as to how much it would cost me if I have mine repaired (assuming I get Samsung panels)?
I really like this monitor because of its unique design.
完成的
@mig25foxbat Total loss situation with the panel most of the time :(. Buy a new monitor if it's annoying and discount sale the old one to someone who can live with it if it's not severe but the cost is too high - some people are okay with gambling and understand the risk.
That monitor uses a desktop panel and it's a commodity resolution (768p; 1366x768) so it isn't a specialty part - it likely comes from a desktop monitor. Not sure about service mode access on that one, but access may be the same if it's a normal control layout.
That uses a CPT panel, so it isn't one of of the expensive 3rd party ones. This is the part number: LCD-PANEL;CLAA185WA03A. Prices vary wildly, but easily found on eBay used - but check the model as there's multple submodels - make sure the part number is exact before you buy since anything that doesn't say CLLA185 will not work. Leave the LCD PANEL; part out - it's not required.
完成的
添加一条评论
Close up images:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mymobilelegendss 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 35
过去 30 天: 176
总计 13,327
