跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
20 个问题 查看全部
Four flashes. Battery isn’t recognized by laptop.
Just replaced my dying battery with one from ifixit.
The white charging light appears when I attach the ac adapter, then I get four orange flashes.
The internet says this means a bad battery. Did I receive a bad battery or is there something else that could be at play here?
EPILOGUE: I followed the recommendation, started the process. For giggles, I unplugged and repeated the connection and realized it had been user error. Fixit troubleshooting 101.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What happens if you leave it on charge for a while, does it stop flashing?
Have you tried re-installing the old battery to check if the problem is still there, assuming that it didn't do this before?
完成的
添加一条评论
2个答案
已选择的解决方案
EPILOGUE: I followed the recommendation of jayeff and started the process of confirming connectivity with the old battery. For giggles, I unplugged and repeated the connection and realized it had been user error. I just hadn’t pushed the connector in far enough. Shame on me. Fixit troubleshooting 101.
这个答案有帮助吗?
得分 0
1条评论:
I am having the same problem you've described, but with no luck on playing with the connection. The old battery re-connected just fine, but the ifixit battery didn't. After hours of sitting plugged in, the flashing orange light continues, and when I unplug the computer it immediately dies. So the battery isn't connecting. Makes me wonder if i got a bad battery.
完成的
添加一条评论
最有帮助的答案
discosammy enter the "Epilogue" as an answer so we can mark this question as resolved.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
discosammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,122
