跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Dim screen Not 6r8?
I have a 3gs with a dim screen so i figured 6r8 coil i have done 2 before so i knew the symptoms. I replaced it and it still has dim screen i even tryed a different coil and still dim screened what else could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
3GS backlight issues seem to be caused by Display LCD, 6R8 coil, or IC 109B. If your LCD Display is good, then hopefully it is the 109B chip. This chip is right next to the coil.
这个答案有帮助吗?
得分 1
3条评论:
I used one off a junk board and when I went to take the chip off my good board i pulled off one of the two pads underneath!!! Is my board junk now??
完成的
Can anyone help me?
完成的
Jared check on this Anyway to reattach solder pads? and click on the link provided by ABCellars. Little bit more on the repairs possible right here http://home.comcast.net/~machrone/bjr/mi... but definitely not as neat. Good Luck
完成的
添加一条评论
I think you need to comfirm your 6r8 is original, since many seller online sell 6r8,but a little bit difference with the one on the 3GS motherboard
I check a site ,the picture is same as on 3GS motherboard, and I get the items from them, it is original and can work
here is the link
http://wiisingonline.com/iPhone-3GS-6r8-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jared 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,578
