跳转到主内容
加入维修社区 - 创建账户
这款笔记本电脑于 2015 年发布,型号为 ba0709dx。维修该设备需要螺丝刀和撬具。
replace keyboard on hp laptop
I am looking to replace the keyboard in my hp 15-db0019au laptop. can anyone help please?
I can’t find this specific laptop here
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
The keyboard in your laptop is part of the top cover assembly and you’ll have to completely dis-assemble the laptop to get to it.
Here’s a link to the Maintenance and service guide for your laptop, taken from this webpage.
The manual details how to dis-assemble the laptop.
On p.76 you’ll find the the part numbers and the country specific part number suffix (if required) for the top cover/ keyboard assembly.
If you search online using the appropriate to your model variant part number (and country suffix if required) only in the search term of your browser you’ll get results for suppliers of the part.
Usually the part number is printed somewhere on the underside of the assembly if you wish to verify that you are ordering the correct part.
这个答案有帮助吗?
得分 2
4条评论:
wow! There's a lot of parts that need removing
完成的
will i need to put more thermal material on?
完成的
Hi,
Check how "dry" it looks.
If it seems crusty and flakes off if you gently pry with a fingernail, clean it all off and refresh it.
There are plenty of videos on YouTube that show how to do this on a CPU or go to p.57 onwards in the manual to see how.
完成的
Thankyou so much
完成的
添加一条评论
添加你的答案
craftcove 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 403
