ONN 50” Tv NO PICTURE
When i turn on my tv, the sound from the playstation will work but there is no picture or display. can anyone point me in the right direction. it worked fine the night before last.
Sydney Chandler try another input source. As a matter of fact, try all different ones. You said you can see it with a flashlight but not without? If so, then this is mainly a backlight issue. You’ll have to take the back cover of your TV and have a look at the voltages from your power board to the backlight LED’s as well as the main board. We would need to know your TV’s exact model and possibly see the boards etc. Once you remove the back cover post some good pictures of your boards etc. with your QUESTION. 在已经存在的问题里加入图片
这个答案有帮助吗?
model number ONA50UB19E05 (H19004-JX)
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 5,753
3条评论
when i put a flashlight to the screen it shows “no signal press input” blah blah blah
由 Sydney Chandler 完成的
I have a 70 in ONN , you can't see it with a flashlight and there is a volume but cannot see the screen.
I need help
由 William Sye 完成的
@williamsye depends on your exact model. could be a bad T-con board, bad main board or worst case a bad panel.
由 oldturkey03 完成的
