跳转到主内容
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
65” Samsung Curved got coffee spilled on it
My TV is actually model UN65MU6500 coffee got spilled on it and now it just turns on and off with a black screen. It acts like it wants to come on then goes back black. And just keeps repeating over and over.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Kyron Perks  at this time you want to stop trying to turn it on. Unplug it and do not use it. The constant on-off attempt can make an already bad situation worse. Remove the back cover from your TV and check the boards and interconnect cables. You should notice any coffee stains etc. you also need to check the top of the panel. that is where the LCD boards connect to the panel via some very fine ribbon cables. Depends on what got “soaked” you may need new power board etc. but we would need to see what your boards etc. look like. Post some good pictures of everything with your QUESTION 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kyron Perks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 145
