跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 个问题 查看全部
Updating Watch OS and/or pairing fails with a new display
After installing a display from another watch I can’t upgrade watch OS 5 to 6. Than I want to reset the watch to pair it once again with my iPhone and it doesn’t work anymore. Any tipps what I can do? :(
Update (07.01.2020)
I found the solution:
the watch must be on watchOS 5 to accept the new display from another watch.
If it fails to update, you have to connect the two cables left and in the middle on the new screen and the right (for NFC/GPS) with the old screen (you must have the old screen!!!) and then pairing and updating will finish!
After the update you can disconnect the old screen and connect the right cable to the new screen.
Re-pairing and updating isn‘t an issue anymore, but if you want to use Apple Pay, the NFC Chip must be replaced with the one from the original screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did you try hard resetting with the new display? If that does not work you may want to try unpairing/factory resetting with the old display on and then perform the swap again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chrkraemer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 196
