跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Face ID Problem- flood illuminator
Hi
I’ve bought from my friend smashed iphone on both sides. Ive repaired it to a brand new condiction- screen and other things are original paired by apple.
There is no error in face id. Main problem is when I try scan, it doesnt recognise my face, its say take phone upper, now lower and… nothing. I’ve found that might be a flood illuminator. I can do soldering by myself but… does this sensors are paired to face id? I wonder if I can replace them (they are mounted to screen with speaker by 3 screws).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi Łukasz Zakrzewski, I am currently facing the same problem with my iPhone Xs Max and I was wondering if replacing the flex cable of the flood illuminator worked. Or was it a different problem?
完成的
添加一条评论
2个答案
最有帮助的答案
YES, the flood illuminator is paired to the phone. It can be transplanted to a new flex cable but it cannot be replaced.
Check out the Face ID teardown guide here and you will know more about Face ID.
为什么维修iPhone后面容 ID会失效
这个答案有帮助吗?
得分 2
添加一条评论
ola,
No meu Iphone 11 o flood illuminator está sempre ativo mesmo quando desativo “pedir atenção para face ID” e “deteção da atenção”..
É normal esse comportamento? nao deveria o flood illuminator se desligar com essas opções desativadas?
这个答案有帮助吗?
得分 0
1条评论:
O que você está vendo é o sensor de proximidade. Ele é junto com o Flood Illuminator.
完成的
添加一条评论
添加你的答案
Łukasz Zakrzewski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 22
总计 4,348
