跳转到主内容
Repair guides and support for your Sanyo TV.
Backlight on the left side is out. Model FVD3934
It seems like the backlight on the left side of the screen is out. Model FVD3934. Just wanna know if there’s a way to fix it cheap or if it would be cheaper to just replace it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Double check your Sanyo model number since there is no information for that model number
完成的
添加一条评论
1个答案
最有帮助的答案
BLAST PROCESSING  is the left side completely dark it is usually not because of a backlight issue but either a panel, LCD driver or T-con issue etc. You want to post some pictures showing what your display shows as well as your boards and interconnect wiring. If the backlight has failed it is possible that this is related to a bad power board or a failed backlight array (strip). A bad power board would be easiest and straight forward. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
2条评论:
@oldturkey03 I thought I would say hi. you know my personal email address right?
完成的
@captainsnowball Hey. welcome back. Yes I do.
完成的
添加一条评论
添加你的答案
BLAST PROCESSING 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 56
