跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
97 个问题 查看全部
Gen 3 firewire iPod not recognized anymore?
So, I pulled the old Gen 3 Ipod out the other day. Used the docking station to charge it up. Works fine, but when I plug it into my Macbook running the latest version of Itunes, it doesn't come up anymore. I tried my GF's old MBP with 10.4 and itunes didn't see it there either... Has Apple stopped support for these devices?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Hmmm... strange...
It plays fine, totally functional. I've tried 3 different cables, but no recognition. I don't want to reformat without backing it up first, i'll lose alot of older stuff that I know I don't have on my new MB. Makes me think maybe the connector on the iPod is fouled or there's a loose wire inside. I did replace the battery and HD about 2 years ago (thank you ifixt!), maybe I jacked something up when I had it apart.
I'll try booting to disk mode tonight. See what that does.
Thanks!
完成的
添加一条评论
6个答案
最有帮助的答案
I had the same problem with mine! So, I booted it up in Disk Mode and it was recognized. If that doesn't work, you may try reformatting in Disk Utility (Which is an app on your Mac in your Utilities folder) and booting it into disk mode. If that doesn't work, try ejecting and reconnecting it a few times. One last thing you could try is - while it's plugged in, lightly knock it against your hand on the left side of the iPod. I've found that this helps when mine is stuck.
How to boot into Disk Mode: http://support.apple.com/kb/HT1363
这个答案有帮助吗?
得分 1
添加一条评论
You might have to reformat I have problems with older ipods to the newer machines. The MBP are "Mactels" CISC Little endian the ipods use ARM processors that are RISC Big Endian (Which are better because it is the way we humans think and recall information). Older format is unreadable on the newer machines. Besides Apple like you to spend money every six months for a new machine and ipod and not to hold on to the old.
这个答案有帮助吗?
得分 0
1条评论:
No apple dosent like that!
完成的
添加一条评论
Yes, it's getting old.
Resetting it into disk mode then reformatting it ("Reset" in iTunes parlance) will help for a bit. I have a 60GB model in the same condition.
Hard disks get old and die eventually.
这个答案有帮助吗?
得分 0
添加一条评论
try to boot it into disk mode, do this by turning it on and holding "Menu" and the center button simultaneously, and than. like the other responses, restore it, and try it, if it doesn't show up, while in disk mode, check if the computer recognizes it at all, it it doesn't, try another cable, if not, than it might be dead, try it on a different computer.
这个答案有帮助吗?
得分 0
添加一条评论
I use one on my iBook G3, and it always pops up. And I have Mac 10.4.11. So it must be your iPod..
这个答案有帮助吗?
得分 0
添加一条评论
This is more of a question. I have one of those older ipods but a very new mac pro computer that has firewire 800 connectors that the original firewire cable that i got with the ipod. Anyone have a solution?
这个答案有帮助吗?
得分 0
1条评论:
Tess you might get a better answer is you ask your own question. Check on the right side of this screen you will find a link that say "Ask a question" and click on it. There you can give as much information as possible and I am sure you will get the help you need. Right now it looks like you are trying to answer a question that is almost a year old. Good Luck.
完成的
添加一条评论
添加你的答案
yeahdude1976 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 7,957
