跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Samsung UA32D5900 32" led tv restarting at every 10 seconds
Hello,
my Samsung led smart tv model no. UA32D5900 has restarting problem. TV is restarting on every 10 seconds interval.
I used all methods like info-menu-mute-power, mute-1-8-2-power ect.. but there is no result. I can’t reset TV with this options.
pl. help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Not resolved. Nothing changed. I have added some images.
完成的
Thanks for your help.
完成的
添加一条评论
1个答案
已选择的解决方案
Nayan Joshi does the screen come on and does the TV actually start fully up? Unplug your TV. Remove the battery from the remote. Disconnect all inputs and soundbar etc. Hold the power button down for about a minute. Then plug one local video source in (DVD/BR/Game Console. stay away from cable or sat box) Then plug the TV in and try to restart. Let us know what you get. If that did not work then the issue could be a damaged (power) board and you will have to remove the back cover and check the power board etc. for any obvious damaged components etc,. Post some pictures of your boards with your question so that we can see what you see.
在已经存在的问题里加入图片
Update (11/07/2019)
Nayan Joshi the problem is your main board. Your processor has totally separated from the board. The only way to repair it is by having some professional reball the processor or you will need to replace the complete main board.
这个答案有帮助吗?
得分 4
1条评论:
Not resolved. I have added some images of my TV circuit.
完成的
添加一条评论
添加你的答案
Nayan Joshi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 1,913
