跳转到主内容
A general-purpose audio device that transmits low audio frequencies to your ears.
Only 1 amp working!
I have 2 amps set up everything is wired up good I checked all my volts with a multimeter ,and everything checks out . But it seems that I can only have 1 amp wired to get any power . I wired each of my amps to 1 power source and each amp started up so is there a reason I can’t set up my highs amp and my bass amp ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@jaimeibarra what make and model are your amps. How did you wire them up? Schematic or picture?
完成的
添加一条评论
1个答案
最有帮助的答案
There might be an issue with the remote turn-on lead. Some radios don’t provide enough current out of the remote lead to turn on multiple amps. Try running 12V from the battery to both of the amps remote turn-on leads and see if they both turn on. If that works, then you can use a relay connected to the radio’s remote turn-on lead and switched 12V power to switch your amps on. Also check to see if you get a voltage drop when both amps turn on at once. It’s possible that one of the amps is going into protection mode due to under-voltage. There could be a wiring, car battery, or alternator problem that isn’t supplying enough current for all your car’s electronics.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jaime Ibarra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 150
