跳转到主内容
The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
101 个问题 查看全部
Cracked screen turned into broken LCD?
Last week I cracked my screen. Took it in to be replaced and the guy said it was just the glass cover that needs replacing. So he replaces it and puts it under the light and I come to fetch it and everything looks great. 10 minutes after I leave the store I notice a small little light spot in the corner of the screen. But as time passes, the light spot just gets bigger and bigger. The next day I took it back and he tells me the glass is lifting and he needs to put it under the light again and I should pick it up the next day. So next day I go fetch my phone and he says sorry I need a whole new LCD. I asked him why we couldnt just replace the glass again and he said that the glass wasn’t the problem. The LCD was. My confusion comes in with this. Why is the LCD now needing to be replaced when there was nothing wrong with it to begin with? Did the glue destroy the LCD?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@desireconfused
anything is possible and replacing the complete display assembly was most likely the right thing to do. There was a reason why the repair did not take the first few times. You do have to trust your repair person. If you don’t then I would suggest you always try someone else.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Desire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 100
