跳转到主内容
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
38 个问题 查看全部
they said the battery is ok, but I need to the machine near the volume
The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour
The repair shop said the battery is fine, but i need to change the machine near the volume button?
what should i do ?
at repairing shop they trying to to fix by replacing the machine with the fake one but i refused and choose to wait the better solution
Please you have any solution or the trusted shop to fix it in Jakarta (indonesia)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Oman Muji all of this “The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour” would make me replace the battery no matter what the repair shop says. I wondered how they tested the battery since it will require a load to show how long it will last. A simple things to do would be to use a USB ammeter when you charge and see how many amps it draws. If it does draw then it is not anything else but the battery. Start with that first.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Oman Muji 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 37
