跳转到主内容
Product Dimensions: 6.3 x 3.1 x 6.3 inches Item Weight: 7.8 ounces Item model number: 04091378 Released: February 2016
2 个问题 查看全部
What battery type is in Marshall Major 2 Bluetooth?
I’ve been using Marshall Major 2 Bluetooth for 22 months. Recently the headphone stopped charging — instead of blinking red light when plugged in, I see a very dim solid white light. I searched in forums and apparently several other people had the same problem. Somebody recommended (aside from the 12-month warranty) replacing the battery.
Is it okay to replace the non-working original battery with an average Lithium Polymer battery? It says somewhere that the original batteries are 680 mAh.
Update (11/11/2019)
Hi @oldturkey03, so I have bought a LiPo battery, but turns out it’s without NTC. The original battery inside the headphone has NTC.
Can I just omit the NTC connection?
The connection inside the headphone:
The battery I bought:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
10条评论
@gizatm personally I would not. NTC is what can keep your battery from overcharging etc. I am not sure if your charger etc. would recognize when to stop charging etc. It might work temporarily but I'd be a little leery and would try to find one that gives me that extra little bit of protection.
完成的
@Coding Tintin  I have the same problem.Is it fixed with the battery you bought ?
please answer.
完成的
@Arman Mkrtchian, unfortunately, not yet. If you look at the image, the battery I bought has only two cables. The Marshall headphones require the third one for NTC. So now I need a battery with three cables. Right now it's not fixed.
If you do fix it, please, write here. Currently I can't find the battery on Alibaba. Might need to look at Amazon.
完成的
@Coding Tintin ok, I will write.
完成的
I have found something like this, and it does look like it should be working like a charm!
I have just ordered it, so it will take a while, to give my review.
https://www.aliexpress.com/item/32996928...
完成的
显示更多的5条评论
添加一条评论
1个答案
已选择的解决方案
@gizatm yes it is for as long as the voltage is the same and the physical size will fit. A lower mAh or greater mAh just means that you may have to recharge the battery faster/lesser.
这个答案有帮助吗?
得分 3
1条评论:
Thank you, I will try fixing it myself with this method.
完成的
添加一条评论
添加你的答案
Coding Tintin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 142
总计 9,112
