跳转到主内容
Comprehensive set of repair guides for playthings for children of all ages.
961 个问题 查看全部
Schematic "Kissing Doll Coin Bank" Toy, Circa 1970, Japan.
The toy arrived disassembled, the cables were not identified, the PCB has no additional identification. Search Google as: "Kising Doll Bank Coin", the one I have, has a heart that lights up.
my english is a work in progress.
Actualización (01/11/19)
The mechanism has 4 switch, 3 physical and one of "coin", the problem is the set-up and synchronization between the melody, its duration and the movement of the figures.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Your English is fine. Without photos we really have no idea of how to help. Trying to find schematics on a fifty year old toy will be next to impossible.
完成的
添加一条评论
1个答案
So the setup of the toy, I’m sure you can alter it for it to work. As far as the synchronization, it usually means that there could be a loose wire preventing the movement of the figures from moving to the melody as soon as it starts up and vise versa. If the duration of the song is not lasting for as long as it should and its cutting off, it could be the battery’s or then again a loose or sliced wire. They are very old and I wish you the best of luck trying to restore/repair it: https://youtu.be/H0jYEcTRTu0
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juan rock 101 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 67
