跳转到主内容
加入维修社区 - 创建账户
丰田最畅销紧凑型轿车的第六代(E90)车型。它也以 E90 Sprinter、Holden Nova 和 Geo Prizm 的名称进行销售。这一代是最后一款被归类为超紧凑型汽车的 Corolla,也是第一款仅提供前轮驱动或全轮驱动的 Corolla(从这一代开始取消了后轮驱动选项)。
this is my problem
first problem of my corolla Toyota is grounded, the battery is becoming weak when engine stop. i used to recharge my battery everyday. when i start, it will start, but when i did not start the engine within three days, the battery would weak and cannot afford to start the engine. until now ,its about one month that the engine did not start. please advise me on how to repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
i dont know on how to answer my question.
完成的
Hi,
If you can charge your battery enough to start the car, once the car has started use a Voltmeter to measure the voltage across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC.
If it measures less than 13.8V DC then there is a problem either with the car's alternator or voltage regulator and the battery is not charging when the motor is running.
If it measures more than 14.5V DC it is overcharging the battery which could damage the battery.
Be safety aware when you do this as the engine is running!
Also ensure that the emergency brake (hand brake) is firmly applied
完成的
My Engine not start.please help me
完成的
Fuel tank is full of soil and rocks
完成的
添加一条评论
1个答案
We need the exact year of your car, also the battery may be shorted internally or have a dead cell so you should charge it up fully, to save time, then take it to your local auto parts store for a free test. If it is good then we can help you find the parasitic drain in your car. This test will involve an amp draw test which will use a multimeter, do you have a multimeter that can test amps? If you have one, do you know how to use it properly to test amps? Here is some help.
https://www.youtube.com/watch?v=KF1gijj0...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Teodoro Achas 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 20
总计 896
