跳转到主内容
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 个问题 查看全部
Can I take the IOpener in an Passenger airplane?
I recived the pixel 2 battery kit today, and in the box I found a big orange label “CARGO AIRCRAFT ONLY“.
It’s because of the IOpener?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Were you able to travel on an airplane with the iopener?
完成的
添加一条评论
1个答案
已选择的解决方案
Mariano Zunino Hernandez
the reason for the “CARGO AIRCRAFT ONLY“ warning is most likely because of the battery included with this kit. The iOpener should be no issue on a passenger plane at all.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mariano Zunino Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 142
